@reck wrote:
Jem my older router has been sent back.
I had no idea I was part of a testing program. VM offered my the Hub 5 (previous had a 3) so I said yes. There was nothing in the email saying it was part in a trial.
If you are not using the Pods, try splitting the SSID on the Hub and manually choosing the best band for each wifi device. Also disable the Smart Optimisation on the wifi.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
Try setting the 2.4Ghz band to a lower legacy setting;
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
