mzeeshan007
Message 1 of 8
Hub 5 doesn’t work when Personalised
I have Hub 5 for a month now,  it was working fine until now. Since yesterday I’m unable to connect to my personalised network. However, when I reset the Hub 5 back to its factory settings, and use the generic network name, it works fine.
It only stops working when I personalise the network name and password.
Devices that are plugged in work fine in either case. It’s the wireless ones that don’t work when I personalise the Hub.
Any idea?
Tags (1)
  • 20.48K
  • 828
  • 2.2K
Message 2 of 8
Re: Hub 5 doesn’t work when Personalised
VM only support Personalise hub when you change to modem mode and stays like that working so get your own router with 1Gb ports.
mzeeshan007
Message 3 of 8
I’ve used it in Router mode and also was able to personalise it for a month. Before Hub 5, I had previous Hubs and that too were personalised in Router mode. If I switch it to Modem mode then I won’t have a network name anymore.
  • 1.87K
  • 116
  • 430
Super solver
Message 4 of 8
The frailty & inflexibility of the Hub 5's Router mode WiFi settings and connectivity are legendary.
If a Hub 5 is delivered here, within the hour I shall be at Currys collecting a 3rd Party WiFi Router.
mzeeshan007
Message 5 of 8
Oh is it? I’m new to Hub5, I thought newer device will mean better service.
I have Google Nest Wifi (1st Gen) as well. I am not happy with it as even though I have Extenders the signals weren’t great in every room.
It looks like it might be better to put Hub 5 in modem mode and just use Google Nest as a primary Wifi network.
Lee_R
  • 6.88K
  • 324
  • 736
Message 6 of 8
Hi mzeeshan007, thanks for posting and welcome back to our community.
There's nothing I can add to what your fantastic fellow community members have already said, sorry.  Please do update us with how things go?
Lee_R
spikey673
  • 251
  • 6
  • 63
Superfast
Message 7 of 8
Are you serious lee? Your opinion as an employee of virgin, is get a 3rd party router? disgusting!
IF i have helped you, please give me kudos / mark me as helpful, thanks
mzeeshan007
Message 8 of 8
I got a new Hub5 which is working fine on the default settings, i.e I haven’t personalised it yet. I’ll try changing it soon but I’m a bit worried what if it breaks down again.
