Hub 5 crashing consistently
AJMoff
I was upgraded to the hub 5 some months ago and for the most part it's been really solid.
Since two days ago however I am getting issues with the modem crashing and requiring a hard power reset to re-engage.
Sometimes it will hold for a few hours other times it can go down again within 15 minutes. It effects both my ethernet connections and WiFi connections, both of which only being restored when I switch the modem off and on again.
According to Virgin media's service page there are no recorded issues in my area.
There have been no tech changes in the house and I haven't prior reconfigured anything either. I'm at a loss as to why its happening.
Any support would be greatly appreciated!
24 REPLIES 24
Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
If nothing shows there can you post up this data...
___________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. On the first page up login and then Navigate to these “pages” and just copy/paste as the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2/3 tables from the Downstream, 2/3 from the Upstream, & the Network Logs page.
Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
AJMoff
Hi jbrennand, thanks for your response.
Using the phone number there were no reports of anything out of order.
Downstream:
12270000002.141QAM 25612
21390000002.640QAM 2561
31470000002.540QAM 2562
41550000002.440QAM 2563
51630000002.340QAM 2564
61710000002.140QAM 2565
71790000002.240QAM 2566
81870000002.340QAM 2567
91950000002.540QAM 2568
102030000002.540QAM 2569
112110000002.641QAM 25610
122190000002.441QAM 25611
132350000001.741QAM 25613
142430000000.940QAM 25614
152510000001.240QAM 25615
162590000001.641QAM 25616
17267000000241QAM 25617
182750000002.341QAM 25618
192830000002.441QAM 25619
202910000002.541QAM 25620
212990000002.741QAM 25621
223070000003.141QAM 25622
233150000003.141QAM 25623
24323000000341QAM 25624
25331000000341QAM 25625
263390000003.440QAM 25626
273470000003.241QAM 25627
28355000000341QAM 25628
293630000002.841QAM 25629
303710000002.941QAM 25630
313790000002.841QAM 25631
1Locked4100
2Locked4000
3Locked4000
4Locked4000
5Locked4000
6Locked4000
7Locked4000
8Locked4000
9Locked4000
10Locked4000
11Locked4100
12Locked4100
13Locked4100
14Locked4000
15Locked4000
16Locked4100
17Locked4100
18Locked4100
19Locked4100
20Locked4100
21Locked4100
22Locked4100
23Locked4100
24Locked4100
25Locked4100
26Locked4000
27Locked4100
28Locked4100
29Locked4100
30Locked4100
31Locked4100
Upstream
05370000043.35120QAM 642
146200000435120QAM 643
23940000042.55120QAM 644
332600000425120QAM 645
0ATDMA0000
3ATDMA0000
21-08-2022 13:18:29warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:18:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:07:25noticeREGISTRATION COMPLETE - Waiting for Operational status
21-08-2022 13:07:19warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:07:14noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:07:11warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:07:09noticeHonoring MDD; IP provisioning mode = IPv4
21-08-2022 13:07:00criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:06:59criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-08-2022 13:06:48criticalCable Modem Reboot due to power button reset
19-08-2022 14:50:30criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-08-2022 14:47:54criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-08-2022 12:29:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
I will investigate with the broadband quality monitor meanwhile!
Thanks again
AJMoff
My Live Graph
Updated with the live graph
BQM not showing anything yet - that's odd ?
Stats look good - Logs tell a different story though
Can you try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
Anything reported there ?
Also, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Disconnect all the connections and reconnect to be sure. Ensure there are no “unterminated cable loose ends or loose wires on the connectors . Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling (no clips piercing, or broken sheathing) and the wall box.
AJMoff
Phone number called - no issues in my area still.
I've gone through all connections and ensured they're all secure. No visible damage on anything - cables, wallbox, hub.
AJMoff
Unsure what's going on with BQM.
Details are all correct - attempted to make a second monitor but it reconfirmed that I was already monitoring the IP address. Server issue maybe?
AJMoff
I am concerned about the logs.
I will ask VM to take a look
