pointzero
  • 7
Message 1 of 9
Hub 5 bricking after switching to Modem Mode
Hi.
Received a Hub 5.
  • Connecting via ethernet adapter manually configured to 192.168.0.5.
  • Has not been connected to VM Coax as to avoid disruption to existing service.
  • Initial device setup completes fine (language select, password reset, wireless settings)
  • Interface works fine. All settings configurable/usable/toggle'able.
  • Device bricks after changing to Modem Mode.
After clicking Apply, the device fails to reset (light stays flashing red), seemingly fails to reconfigure itself to be reachable via 192.168.100.1, as after updating local ethernet to be 192.168.100.5 - no ping and no HTTP interface available.
Device remains ping'able via 192.168.0.1 - although interface is now unreachable. Rebooting the device brings it back up with only ping to 192.168.0.1. No interface. Nothing on 192.168.100.1.
Factory Reset restores successfully, and device is then reachable again via 192.168.0.1.
Have tried 6-7 times, using different ethernet ports, disabling wireless first, then switching. No change in end result.
Anyone had same/similar issue?
Thanks!
  • 1.85K
  • 115
  • 425
Super solver
Message 2 of 9
Re: Hub 5 bricking after switching to Modem Mode
DOCSIS Hubs have almost no functionality in isolation.
Connect the Hub 5 to the coax cable & then switch to modem mode.
Resistance is futile !
pointzero
  • 7
Message 3 of 9
My current Hub 3 is in Modem Mode. Interface is always reachable via 192.168.100.1.
Connecting new Hub would switch service off for my Hub 3 locking me into Router Mode on this hub till Modem Mode can be fixed.
Not cool with that.
also; there's no reason why a management interface would never be available, unless of fault.
  • 15.83K
  • 2.1K
  • 4.97K
Message 4 of 9
@pointzero wrote:
Hi.
Received a Hub 5.
Thanks!
It needs connecting to the coax
Dave
Love, love and love, forever - Pele
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Message 5 of 9
Hi pointzero,
The Hub 5 is a replacement for the Hub 3 and once delivered, the Hub 3 will likely become inactive within a few days.
You will need to connect the Hub 5 via the coax cable in order for it to work.
If after doing this you are still having issues, please pop back and let us know.
Kath_F
unisoft
  • 721
  • 20
  • 268
Rising star
Message 6 of 9
Not cool with that.
disconnect the HUB3, plug in the hub 5 with coax connected. Within 10 minutes job done. Modem mode.
Needs to be connected to reconfigure for modem mode...
  • 20.47K
  • 828
  • 2.2K
Message 7 of 9
See what happens when you disconnect Coax from your hub 3 then try 192.168.100.1 it will not work or at least over time when it tries to arp to the WAN getaway it will fail. The reason for this is the bridge picks up traffic going to 192.168.100.1 to the WAN gateway so no Coax no arp no WAN gateway.
If you configure a PC to to use 192.168.100.2/24 gateway 192.168.100.1 then you should be able to get to 192.168.100.1
pointzero
  • 7
Message 8 of 9
To update and close/resolve thread.
Hub5 config is locked until the modem syncs with the mothership.
So whilst I was unable to configure the device as I needed to prior to connecting, once connected, I was able to make the adjustment.
It wasn't clear that this would be the case but once confirmed by engineer at VM - I was happy to try it and see, with the agreement that the engineer could reactive my Hub3 if things hit the fan.
Carley_S
  • 3.07K
  • 162
  • 263
Message 9 of 9
Hi @pointzero
Thank you for updating us . Glad to hear that you were able to connect and make the needed adjustments. Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
Carley - Forum Team
