on 21-07-2023 06:53
I have recently moved to a Virgin media home hub 5 on the 1Gbps package.
When using the hub directly, I get 850Mbps on cat6 ethernet cable or 750Mbps on 5ghz wi-fi.
>> Internet > Hub in router mode > Laptop
When I set the hub to modem mode and connect to my Archer v6 via cat6 ethernet cable, I only get 80Mbps down on wi-fi and 120Mbps on cat6 ethernet. When I connect directly to the hub in modem mode, I'm still getting 850Mbps on cat6 ethernet.
>> Internet > Hub in modem mode > Router > Laptop
I have checked all the settings on my router and nothing should be causing this throttling. I have replaced the ethernet cables with brand new cat6 cables and this is still not working. I have confirmed the issue on three different laptops (windows 10 & 11) and two mobiles (android and apple). I have also tried AP mode and get the same issue.
At all times I am using the 2.5Gbps port on the hub, but have tried the other 1Mbps ports with the same issue.
Any ideas how I can fix this? It feels like the hub is throttling my connection somewhere!
on 21-07-2023 08:06
Having confirmed the speed is available at the Hub.
It reads like the Archer Router is limiting the performance. Check QoS / DPI are fully disabled.
on 21-07-2023 10:51
might be a faulty TP-Link or try copying your PC MAC to your router and see what hapens
