Hub 5 and Power line adapters
monkeyplums
I've recently had a hub upgrade to the hub 5 however my existing powerline adapters don't connect. Can someone advise pls
2 REPLIES 2
Cardiffman282
Super solver
I'd bin the VM powerline adapters. They are a proven fire risk. VM now do pods https://www.virginmedia.com/virgin-tv-edit/tips-and-tricks/boost-your-wifi-with-virgin-media-intelli... but buying your own router would be cheaper in the long run.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
Legend
If we were changing from a BT / Plusnet / TalkTalk Router to a VM Hub the IP address range of the Powerline adaptor's menus may need to be reset.  But here that does not appear to be the case.
For a change of VM Hub I would expect to power off all the Powerline adaptors ( and any network switches ) and then power them all back on once the new Hub 5 was up and running.
Similarly all attached equipment ( cameras / laptops / TV / printers etc ) will need to be power cycled to ensure every device requests and IP address from the Hub 5.
Unless the Powerline adaptors have become unpaired, reconfiguration should not be needed.
