on 24-03-2023 19:04
Hello,
I have found that my Hub5 is not allowing WiFi calling for an iPhone 13 and iPhone 11 both on the most recent iOS release. We have tried resetting network settings on the iPhones but this hasn’t worked.
We are in a dead spot for 4g with only ~ 1 bar, so Wi-Fi calling is needed. It was working when we had the hub 4!
Is there a setting that can be changed on the router? Or am I going to have to buy a mesh..
Jack
on 24-03-2023 19:13
Make sure that your iPhones have Apple's Private Browsing / Private IP Disabled. ( all VPN tools )
The link below should return Virgin Media Limited as the ISP
https://whatismyipaddress.com/
on 24-03-2023 19:52
on 26-03-2023 14:55
After a couple of resets on the phone some calls are going through with WiFi calling. But we are experiencing frequent call drops.
My friend is also with Virgin Media but uses an Eero mesh and WiFi calling works without issue.
on 26-03-2023 23:41
@CaptainMcScrump wrote:My friend is also with Virgin Media but uses an Eero mesh and WiFi calling works without issue.
Do you wonder why that is or should I?
on 29-03-2023 09:50
Hi CaptainMcScrump 👋
Thanks for posting and welcome back to our Community Forums.
I'm sorry to hear you're experiencing some trouble with Wi-Fi Calling on your devices. To confirm, is it just both iPhones that are experiencing problems, or other devices that have Wi-Fi Calling capabilities too?
Can you also confirm whether Wi-Fi Calling is something your Mobile Network Provider supports as well and is activated on their end? Have you made any changes to your Hub in the past, or have any active firewalls/configurations? If so, have you tried reverting these?
Cheers,
on 06-04-2023 22:52
I setup a mesh network with Eero Pro 6.
No issue with WiFi calls dropping and getting 600Mbps upstairs vs 200Mbps with the virgin router and extender.
Thanks for your support.
on 10-04-2023 13:37
Hi @CaptainMcScrump,
Thank you for the update. I'm glad to hear that you've now been able to resolve your concerns.
Please do let us know if there's anything more that we can assist you with.
