Hello all.
I have recently been upgraded to the virgin volt 1gbs service and the problem I have is that my router is in the attic and I had it connected to my develo mesh Wi-Fi 2 power lines on the ground floor (connected via Ethernet from the router) and everything was working fine on the ground floor from the living to the garage.
since the upgrade to the hub 5 I keep losing connections on my power line every minute for about 10 seconds and it causes issues with my ring doorbell etc when viewing the feed it keeps freezing/pausing. I am not sure if it is because the hub 5 is Wi-Fi 6 or maybe something else. I have tried factory resetting the develos moving them etc but they still keep losing connection.
I was wondering if someone can advise me if I can maybe buy a couple of routers and link them to my hub 5 router in the attic via Ethernet or some Wi-Fi hotspots ? Virgin sent me the Wi-Fi pods which do a good job but problem is that I cannot get a connection in the garage via the pods but they do work well in other places but I need to get Wi-Fi also to the garage as I have my car charger there.
thanks in advance for anyone responding trying to help !!
