on 19-05-2022 16:51
I noticed that some old devices like iPads, have a very slow wifi speed.
For example a phone next to my iPad shows a speed of 250mbps but the iPad achieves only 40mbps. Both are non Wifi6 devices.
Any reason why please.
on 19-05-2022 17:23
The iPad could be on the 2.4Ghz band and the phone on the 5GHz band. The only way to force the iPad to the 5GHz band is to go into the settings on the hub and split the bands to different SSIDs, say xxx-2 and xxx-5. Then connect the iPad to the xxx-5 band.
on 19-05-2022 17:25
Hi both on 5ghz.
on 22-05-2022 15:10
Hi amoVM,
Thanks for posting - apologies for the low speeds. I've done a system check and your upstream levels need sorting as they're too low. I'll send a tech for this. It may not solve the speeds however so relating that, can you do a wired non-console speedtest at http://speedtest.net for me with only that device connected to the internet? This'll give us an indication of the actual speeds you're receiving and we can go from there.
I'll send you the PM for the tech visit now.
Best,
on 22-05-2022 15:45
The speeds look fine on Ethernet 946 / 52
I can only assume the slow speeds on the old devices are due to hardware limitations?
on 24-05-2022 18:05
Thanks for checking.
It can be for a number of reasons @amoVM especially when WiFi is concerned.
We have some tips here that may help - How to Improve WiFi
Let us know if you have any further questions.
on 25-05-2022 14:38
Hey amoVM, I am very happy to see a engineer came to fix this issues you and replaced your hub.
If you ever need anything again you know where to find us. Thanks
Matt - Forum Team
New around here?
on 25-05-2022 14:39
Please note he said there was nothing wrong the the upstream levels on the old router.
on 27-05-2022 14:45
Hi amoVM,
Thanks for the update.
I've had a look at things from our side and everything looks to be in order after the visit.
If you do still need help with anything please let us know.
Alex_Rm
on 27-05-2022 14:55
what has changed since the router replacement pls?
