Hub 5 - Port forward both 443 and 8123 to 8123
JGHSmith
I need to forward ports 8123 and 443 to 8123 however when I try to set the second rule the hub5 gives me an error message "overlapping rules". How do I fix this?
2 REPLIES 2
Sabrina_B
Hi @JGHSmith 👋.
We cannot recommend personalising settings on your Hub as this is designed and calibrated for optimum performance, also whilst you attempt to adjust the settings you forward a port you send all traffic to a single address. If you need 2 devices to receive the data on the same port then you need to forward it to a single device that connects those 2 additional devices to the network.
Sabrina
@Sabrina_B wrote:
Hi @JGHSmith👋.
Sabrina
Lost in translation.😜
Anyway other routers can forward ports 8123 and 443 to 8123 to a given IP just not the hub and yes VM will do nothing to help you with that
