on 15-08-2023 18:00
15-08-2023 18:06 - edited 15-08-2023 18:06
VM Pods are paired to one Hub,
If the original Hub is replaced the VM Pods become inoperable & need to be replaced or need VM to re-pair them to the new Hub 5.
on 15-08-2023 20:41
Hi aliendon73, thanks for the message and sorry to hear that you are having issues with the pods.
I will send you a PM so that this can be looked into further.
Kind regards, Chris.
