on 18-12-2021 14:05
Hi there,
I used to have a hub 3 that would regularly disconnect and was impressed that for the first week my new hub 5 would be online 24/7. It was a miracle.
Now about 2 weeks later I am plagued with packet loss and random high latency every few seconds, see image attached.
I had a technician come round who had no idea how to test my internet other than speedtest on his phone. It was honestly embarassing, he didn't know what BQM was or even what I was doing when pinging google.
Please help.
Jon
on 21-12-2021 07:32
Yes I am an FTTP customer
on 21-12-2021 08:09
Hi Jonnyboybick
Thank you for all those stats. I can also see from here the levels are a bit out
I would need to pass security with you to arrange a service technician to attend
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 21-12-2021 17:53
Engineer booked for thursday. Lookat my bqm in my signature. Absolute joke.
on 23-12-2021 17:20
Engineer came round today. He was a bit more knowledgeable although still didn't know what a BQM was, which I find bizarre as it's usually the first thing people setup when they have internet issues.
He replaced the hub 5 and says power levels were fine. I am still experiencing the issue though, will give it 24 hours to settle before judging.
on 26-12-2021 08:43
Issue not fixed, here are the new logs:
1 | 491000000 | 2.3 | 40 | QAM 256 | 11 |
2 | 411000000 | 2.2 | 40 | QAM 256 | 1 |
3 | 419000000 | 2.4 | 40 | QAM 256 | 2 |
4 | 427000000 | 2.3 | 40 | QAM 256 | 3 |
5 | 435000000 | 2.4 | 40 | QAM 256 | 4 |
6 | 443000000 | 2.4 | 40 | QAM 256 | 5 |
7 | 451000000 | 2.3 | 40 | QAM 256 | 6 |
8 | 459000000 | 2.5 | 40 | QAM 256 | 7 |
9 | 467000000 | 2.5 | 40 | QAM 256 | 8 |
10 | 475000000 | 2.4 | 41 | QAM 256 | 9 |
11 | 483000000 | 2.4 | 41 | QAM 256 | 10 |
12 | 499000000 | 2.1 | 40 | QAM 256 | 12 |
13 | 507000000 | 2.1 | 41 | QAM 256 | 13 |
14 | 515000000 | 2 | 41 | QAM 256 | 14 |
15 | 523000000 | 2 | 41 | QAM 256 | 15 |
16 | 531000000 | 2.1 | 41 | QAM 256 | 16 |
17 | 539000000 | 2 | 41 | QAM 256 | 17 |
18 | 547000000 | 2.1 | 41 | QAM 256 | 18 |
19 | 555000000 | 2.1 | 41 | QAM 256 | 19 |
20 | 563000000 | 2.1 | 41 | QAM 256 | 20 |
21 | 571000000 | 2.2 | 41 | QAM 256 | 21 |
22 | 579000000 | 2 | 41 | QAM 256 | 22 |
23 | 587000000 | 1.9 | 41 | QAM 256 | 23 |
24 | 595000000 | 1.9 | 41 | QAM 256 | 24 |
25 | 603000000 | 1.7 | 40 | QAM 256 | 25 |
26 | 611000000 | 1.8 | 41 | QAM 256 | 26 |
27 | 619000000 | 1.9 | 40 | QAM 256 | 27 |
28 | 627000000 | 1.9 | 40 | QAM 256 | 28 |
29 | 635000000 | 2.1 | 40 | QAM 256 | 29 |
30 | 643000000 | 2.1 | 40 | QAM 256 | 30 |
31 | 651000000 | 2.2 | 40 | QAM 256 | 31 |
1 | Locked | 40 | 0 | 0 |
2 | Locked | 40 | 0 | 0 |
3 | Locked | 40 | 0 | 0 |
4 | Locked | 40 | 0 | 0 |
5 | Locked | 40 | 0 | 0 |
6 | Locked | 40 | 0 | 0 |
7 | Locked | 40 | 0 | 0 |
8 | Locked | 40 | 0 | 0 |
9 | Locked | 40 | 0 | 0 |
10 | Locked | 41 | 0 | 0 |
11 | Locked | 41 | 0 | 0 |
12 | Locked | 40 | 0 | 0 |
13 | Locked | 41 | 0 | 1 |
14 | Locked | 41 | 0 | 0 |
15 | Locked | 41 | 0 | 0 |
16 | Locked | 41 | 0 | 0 |
17 | Locked | 41 | 0 | 0 |
18 | Locked | 41 | 0 | 0 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 1 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 41 | 0 | 0 |
24 | Locked | 41 | 0 | 1 |
25 | Locked | 40 | 0 | 0 |
26 | Locked | 41 | 0 | 0 |
27 | Locked | 40 | 0 | 1 |
28 | Locked | 40 | 0 | 1 |
29 | Locked | 40 | 0 | 0 |
30 | Locked | 40 | 0 | 1 |
31 | Locked | 40 | 0 | 1 |
1 | 60300000 | 31.8 | 5120 | QAM 64 | 1 |
2 | 53700000 | 31.8 | 5120 | QAM 64 | 2 |
3 | 46200000 | 31.3 | 5120 | QAM 64 | 3 |
4 | 39400000 | 30.8 | 5120 | QAM 64 | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
26-12-2021 03:07:46 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:07:14 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:07:13 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
26-12-2021 03:07:07 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:07:01 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:59 | critical | DHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:58 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:58 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:56 | notice | Honoring MDD; IP provisioning mode = IPv4 |
26-12-2021 03:06:51 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:51 | critical | DHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:50 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:47 | critical | DHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:41 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:40 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-12-2021 03:06:36 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-12-2021 18:27:34 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-12-2021 18:27:30 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-12-2021 18:25:14 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-12-2021 13:34:11 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 17:02:02 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 16:46:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 14:46:58 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 14:46:30 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 14:42:31 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-12-2021 14:39:47 | critical | Resetting the cable modem due to docsDevResetNow |
on 26-12-2021 09:51
Your BQM is shocking, looks like noise somewhere on the line.
on 26-12-2021 20:00
Thanks for acknowledging, I feel like I'm going insane!
on 04-01-2022 13:44
Hi again,
Engineer out today, same guy as the first one. I wasn't very optimistic but I made him a coffee and he spent a couple of hours here trying to the sort the issue out.
What he did:
Removed the splitter to the TV as we don't use that anymore.
Replaced the coaxial from the wall to the hub.
Replaced the hub 5 with a hub 4.
After replacing the coaxial it was working quite well for about 10 minutes so he removed the old coaxial from the wall and clipped in the new one. Then he cut the cable shorter and since then the issue seems to have returned (I could also have just been really lucky for those 10 minutes).
See images:
on 06-01-2022 10:02
on 06-01-2022 12:28
Wow, thats a horrendous BQM, it's got to be a network fault.
Some sort of noise ingress perhaps, you're not going mad and no it's not you at fault this is up to virgin to fix.
