Jonnyboybick
  • 126
  • 5
Message 1 of 50
Hub 5 Packet loss and latency
Hi there,
I used to have a hub 3 that would regularly disconnect and was impressed that for the first week my new hub 5 would be online 24/7. It was a miracle.
Now about 2 weeks later I am plagued with packet loss and random high latency every few seconds, see image attached.
I had a technician come round who had no idea how to test my internet other than speedtest on his phone. It was honestly embarassing, he didn't know what BQM was or even what I was doing when pinging google.
Please help.
Jon
My BQM
Tags (2)
Jonnyboybick
  • 126
  • 5
Message 2 of 50
Re: Hub 5 Packet loss and latency
You can see my BQM in signature.
My BQM
  • 20.48K
  • 828
  • 2.2K
Message 3 of 50
A bit of line noise by the looks of it.
carl_pearce
  • 1.76K
  • 114
  • 377
Super solver
Message 4 of 50
Could you post your HUB stats?
Jonnyboybick
  • 126
  • 5
Message 5 of 50
Thanks for the reply, unfortunately when I try and access my hub stats I get the below error:
My BQM
Jonnyboybick
  • 126
  • 5
Message 6 of 50
Upstream I can view:
16030000031.35120QAM 641
25370000031.35120QAM 642
34620000030.85120QAM 643
43940000030.35120QAM 644
3ATDMA0000
4ATDMA0000
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
1
Enabled
3.1
3254k;fg87dsfd;kfoA,.iyew
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
13287
230000061 bps
42600 bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
12801
22000061 bps
42600 bytes
0 bps
42600 bytes
Best Effort
19-12-2021 18:49:08noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 1 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1
19-12-2021 18:48:54noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 1 3 4 5 6 7 8 9 10 11 12 13 14 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 18:48:35warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 18:48:31criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 18:48:30warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 18:48:30warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 18:48:24criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 03:07:33noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 03:07:10noticeREGISTRATION COMPLETE - Waiting for Operational status
19-12-2021 03:07:04warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 03:06:59noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 03:06:55warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-12-2021 03:06:53noticeHonoring MDD; IP provisioning mode = IPv4
19-12-2021 03:06:44criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:50:26criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:50:06criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:50:06criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:49:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:49:46criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-12-2021 12:49:26criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
My BQM
carl_pearce
  • 1.76K
  • 114
  • 377
Super solver
Message 7 of 50
Upstream power levels look low, unless you are in a FTTP area?
Jonnyboybick
  • 126
  • 5
Message 8 of 50
Thanks for the reply. I think I'm in an FTTP area. I'm more concerned with not being able to access my downstream logs and have seen a couple of other posts about downstream issues with the hub 5.
I did ask the engineer to check my power levels when he came but he never did.
My BQM
Jonnyboybick
  • 126
  • 5
Message 9 of 50
Can someone kindly review my message and book me in a technician as if I phone again the technician is going to be the same guy who uses his mobile to speedtest and confirm that my internet is ok.
My BQM
  • 13.88K
  • 1.07K
  • 2.81K
Message 10 of 50
 If you are not a FTTP customer then those upstream power levels are too low. You can tell if you are FTTP customer if you have a VM power plug that takes a coax cable usually going to a white box. I do not mean a power plug for your VM hub or TV box.
