Hello
I’ve been going in circles trying to fix this and was hoping someone could push me in the right direction.
Move from BT hub to Virgin Hub 5 today. BT was slow but worked. Installed the hub 5 today and everything connected fine APART from my PC. (Which is still working fine with BT) It just doesn’t show up at all when I look for networks. It fine my entire street it seems, but not the new hub.
The PC just cannot find the new hub, despite finding the old hub and other devices still find the new hub.
I’ve been into the setting and tried everything but nothing works. Rang support for my PC (still in warranty) and the they said must be a setting in the hub not working - since the PC is working with everything else (and work fine via Ethernet)
Any clues at all? I’ve booked an engineer but if it doesn’t get resolved I’m not sure if I’ll need a new WI-FI card or new hub?
Failing this - can I turn my hub into modem mode and pick up a router to make it work that way?
