on 11-08-2023 19:53
I have found some errors and would like some advice if I should be concerned.
1 | 331000000 | 5.1 | 39 | QAM 256 | 25 |
2 | 139000000 | 8.6 | 37 | QAM 256 | 1 |
3 | 147000000 | 8.4 | 37 | QAM 256 | 2 |
4 | 155000000 | 7.9 | 37 | QAM 256 | 3 |
5 | 163000000 | 7.6 | 37 | QAM 256 | 4 |
6 | 171000000 | 7.4 | 38 | QAM 256 | 5 |
7 | 179000000 | 7.1 | 38 | QAM 256 | 6 |
8 | 187000000 | 7 | 38 | QAM 256 | 7 |
9 | 195000000 | 7.1 | 38 | QAM 256 | 8 |
10 | 203000000 | 6.9 | 38 | QAM 256 | 9 |
11 | 211000000 | 6.9 | 38 | QAM 256 | 10 |
12 | 219000000 | 6.5 | 38 | QAM 256 | 11 |
13 | 227000000 | 5.8 | 38 | QAM 256 | 12 |
14 | 235000000 | 5.4 | 38 | QAM 256 | 13 |
15 | 243000000 | 5.2 | 38 | QAM 256 | 14 |
16 | 251000000 | 4.8 | 38 | QAM 256 | 15 |
17 | 259000000 | 4.8 | 38 | QAM 256 | 16 |
18 | 267000000 | 4.7 | 38 | QAM 256 | 17 |
19 | 275000000 | 4.9 | 38 | QAM 256 | 18 |
20 | 283000000 | 5.1 | 38 | QAM 256 | 19 |
21 | 291000000 | 5.4 | 38 | QAM 256 | 20 |
22 | 299000000 | 5.5 | 39 | QAM 256 | 21 |
23 | 307000000 | 5.5 | 39 | QAM 256 | 22 |
24 | 315000000 | 5.4 | 39 | QAM 256 | 23 |
25 | 323000000 | 5.3 | 39 | QAM 256 | 24 |
26 | 339000000 | 5.2 | 40 | QAM 256 | 26 |
27 | 347000000 | 5 | 40 | QAM 256 | 27 |
28 | 355000000 | 4.9 | 40 | QAM 256 | 28 |
29 | 363000000 | 4.8 | 40 | QAM 256 | 29 |
30 | 371000000 | 4.3 | 40 | QAM 256 | 30 |
31 | 379000000 | 4 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 64 | 0 |
2 | Locked | 37 | 107 | 0 |
3 | Locked | 37 | 104 | 0 |
4 | Locked | 37 | 92 | 0 |
5 | Locked | 37 | 95 | 0 |
6 | Locked | 38 | 90 | 0 |
7 | Locked | 38 | 89 | 0 |
8 | Locked | 38 | 81 | 0 |
9 | Locked | 38 | 91 | 0 |
10 | Locked | 38 | 92 | 1 |
11 | Locked | 38 | 98 | 0 |
12 | Locked | 38 | 75 | 0 |
13 | Locked | 38 | 85 | 0 |
14 | Locked | 38 | 81 | 0 |
15 | Locked | 38 | 63 | 0 |
16 | Locked | 38 | 80 | 0 |
17 | Locked | 38 | 42 | 0 |
18 | Locked | 38 | 43 | 0 |
19 | Locked | 38 | 36 | 0 |
20 | Locked | 38 | 36 | 0 |
21 | Locked | 38 | 44 | 0 |
22 | Locked | 39 | 43 | 0 |
23 | Locked | 39 | 42 | 0 |
24 | Locked | 39 | 62 | 0 |
25 | Locked | 39 | 47 | 0 |
26 | Locked | 40 | 77 | 0 |
27 | Locked | 40 | 78 | 0 |
28 | Locked | 40 | 65 | 28 |
29 | Locked | 40 | 74 | 54 |
30 | Locked | 40 | 89 | 41 |
31 | Locked | 40 | 72 | 14 |
Answered! Go to Answer
on 11-08-2023 20:01
There are some Downstream errors across all channels, now I'd not be concerned unless the numbers started to ramp up and thousands of error were being logged. If error counts remain stable, then we are are only seeing the result of a past glitch that is re-solved.
With things like this all we can do it check our own cable from the Hub to the wall socket are secure at both ends and if the system is working fine, it is time to enjoy the weekend.
on 11-08-2023 19:54
0 | 49600000 | 38.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 37.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 36.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 34.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 34 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 1 | 0 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 11-08-2023 19:54
General Configuration
Allowed |
1 |
Enabled |
3.1 |
254k;fg87dsfd;kfoA,.iyewr |
8690 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
8689 |
110000274 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
on 11-08-2023 19:55
Time | Priority | Description |
11-08-2023 19:15:50 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
11-08-2023 19:15:50 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
11-08-2023 18:10:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
11-08-2023 18:10:06 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
11-08-2023 18:08:51 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
11-08-2023 18:08:51 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 17:29:15 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 16:53:21 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 16:53:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 15:51:37 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 15:51:37 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 20:23:19 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 20:23:19 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 19:22:05 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 19:22:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 19:13:46 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:47 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:47 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:43 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
08-08-2023 18:50:38 | warning | Dynamic Range Window violation |
08-08-2023 18:50:38 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:37 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:32 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:28 | notice | TLV-11 - unrecognized OID;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:26 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:24 | notice | Honoring MDD; IP provisioning mode = IPv4 |
08-08-2023 18:50:07 | critical | No Ranging Response received - T3 time-out;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:50:01 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 18:49:43 | critical | Cable Modem Reboot via RG reboot command |
08-08-2023 18:46:20 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=xx xx xx xx xx xx ;CMTS-MAC=xx xx xx xx xx xx ;CM-QOS=1.1;CM-VER=3.1; |
on 11-08-2023 20:01
on 12-08-2023 12:46
Hi all,
Check the system status again today and found these logged errors increasing.
1 | Locked | 39 | 87 | 0 |
2 | Locked | 37 | 126 | 0 |
3 | Locked | 37 | 128 | 0 |
4 | Locked | 37 | 117 | 0 |
5 | Locked | 37 | 117 | 0 |
6 | Locked | 37 | 109 | 0 |
7 | Locked | 38 | 107 | 0 |
8 | Locked | 38 | 104 | 0 |
9 | Locked | 38 | 117 | 0 |
10 | Locked | 38 | 113 | 1 |
11 | Locked | 38 | 116 | 0 |
12 | Locked | 38 | 95 | 0 |
13 | Locked | 38 | 114 | 1 |
14 | Locked | 38 | 104 | 0 |
15 | Locked | 38 | 82 | 0 |
16 | Locked | 38 | 96 | 0 |
17 | Locked | 38 | 57 | 0 |
18 | Locked | 38 | 61 | 0 |
19 | Locked | 38 | 43 | 0 |
20 | Locked | 38 | 49 | 0 |
21 | Locked | 38 | 55 | 0 |
22 | Locked | 39 | 62 | 0 |
23 | Locked | 39 | 53 | 0 |
24 | Locked | 39 | 71 | 0 |
25 | Locked | 39 | 66 | 0 |
26 | Locked | 39 | 92 | 0 |
27 | Locked | 39 | 98 | 0 |
28 | Locked | 40 | 84 | 28 |
29 | Locked | 40 | 97 | 56 |
30 | Locked | 39 | 108 | 41 |
31 | Locked | 39 | 91 | 15 |
on 12-08-2023 12:57
Nothing to be concerned about.
on 12-08-2023 13:39
Hi Carl,
After reading more on these forums and taking in what other have said I decided to turn off the Hib 5 and relocate it . In doing this I could check all the cables are OK and tightened correctly and resetting the Hubs Log. Now when I check I have Zero across the board.
Only errors logged are:
0 | ATDMA | 0 | 1 | 0 | 0 |
1 | ATDMA | 0 | 1 | 0 | 0 |
2 | ATDMA | 0 | 1 | 0 | 0 |
3 | ATDMA | 0 | 1 | 0 | 0 |
4 | ATDMA | 0 | 1 | 0 | 0 |
As far as I can understand, these are nothing to worry about.
Thank again
