Hub 5 Dropping DOCSIS Connection
GeoBarb
Hi people,
We recently installed a new VM Hub 5, but just as the last (Hub 3) the connection is still being dropped. This has happened twice in the past 24 hours or so and is regular occurrence.
Error in Network log file reads as follows:
20-04-2023 02:52:08noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER
=3.1;
20-04-2023 02:52:08warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:52:01noticeREGISTRATION COMPLETE - Waiting for Operational status
20-04-2023 02:51:55warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:55warningDynamic Range Window violation
20-04-2023 02:51:55warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:55warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:50noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:46noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:44warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:42noticeHonoring MDD; IP provisioning mode = IPv4
20-04-2023 02:51:32criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-04-2023 02:51:15criticalCable Modem Reboot via RG reboot command
Current Status
Item Status Comments
Acquired Downstream Channel(Hz)306000000Locked
Ranged Upstream Channel(Hz)49600000Ranged
Provisioning StateOnlineOperational
04960000042.35120QAM 641
143100000425120QAM 642
23660000042.35120QAM 643
33010000041.85120QAM 644
42360000041.85120QAM 645
13060000006.239QAM 25622
21380000002.837QAM 2561
31460000002.537QAM 2562
41540000002.738QAM 2563
51620000002.938QAM 2564
61700000003.138QAM 2565
71780000003.438QAM 2566
81860000003.638QAM 2567
9194000000438QAM 2568
102020000004.338QAM 2569
112100000004.138QAM 25610
122180000003.838QAM 25611
132260000003.738QAM 25612
142340000003.538QAM 25613
152420000003.838QAM 25614
162500000004.339QAM 25615
172580000004.839QAM 25616
182660000005.539QAM 25617
192740000005.739QAM 25618
202820000005.439QAM 25619
212900000005.739QAM 25620
222980000006.139QAM 25621
233140000006.239QAM 25623
243220000006.339QAM 25624
253300000006.640QAM 25625
263380000007.140QAM 25626
273460000006.840QAM 25627
283540000006.440QAM 25628
293620000006.640QAM 25629
303700000006.840QAM 25630
313780000006.940QAM 25631
More to follow..
10 REPLIES 10
graham1705
hi internet drop could you have a look
30-08-2023 18:39:49warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:39:05warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:20noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:20warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:17noticeREGISTRATION COMPLETE - Waiting for Operational status
30-08-2023 18:38:10warningDynamic Range Window violation
30-08-2023 18:38:10warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:10warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:38:04noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:52warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:50noticeHonoring MDD; IP provisioning mode = IPv4
30-08-2023 18:37:37criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
30-08-2023 18:37:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
