Hub 5 - Connection Issues
CJBoyd
Current Set-up:
1Gig - Hub 5 (Modem Mode) connected to third part router.
Issue:
Regular connection issues with dropped packets and high latency
Following post of my current logs (rebooted 2 days ago)
4 REPLIES 4
CJBoyd
13710000002.741QAM 25630
21390000005.440QAM 2561
31470000005.240QAM 2562
41550000005.140QAM 2563
5163000000540QAM 2564
61710000004.940QAM 2565
71790000004.740QAM 2566
81870000004.640QAM 2567
91950000004.640QAM 2568
102030000004.440QAM 2569
112110000004.441QAM 25610
122190000003.940QAM 25611
132270000003.540QAM 25612
142350000003.240QAM 25613
152430000003.240QAM 25614
162510000003.341QAM 25615
172590000003.140QAM 25616
182670000003.140QAM 25617
192750000003.140QAM 25618
202830000003.341QAM 25619
212910000003.440QAM 25620
222990000003.341QAM 25621
233070000003.241QAM 25622
243150000003.241QAM 25623
253230000003.341QAM 25624
263310000003.241QAM 25625
273390000003.341QAM 25626
283470000003.241QAM 25627
293550000003.241QAM 25628
30363000000341QAM 25629
313790000002.641QAM 25631
1Locked41341344299
2Locked40837109725
3Locked4014762917403
4Locked4010519812202
5Locked40563537264
6Locked40399124756
7Locked40770418256
8Locked4010618113106
9Locked40431104201
10Locked40316193304
11Locked41226362550
12Locked40353102785
13Locked40358502739
14Locked40282042011
15Locked40237752110
16Locked41138441298
17Locked40251571893
18Locked40258142274
19Locked40308172623
20Locked41190721262
21Locked40255674161
22Locked41221422235
23Locked41247142145
24Locked41353212974
25Locked41200251938
26Locked41143421415
27Locked41116741710
28Locked41196121796
29Locked41244512706
30Locked41227272001
31Locked41117761238
CJBoyd
04960000047.85120QAM 641
14310000047.55120QAM 642
23660000047.35120QAM 643
33010000047.35120QAM 644
42360000046.85120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0000
CJBoyd
18-07-2023 21:09:10warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 21:09:10noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:59:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:59:07warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:38:53noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:38:53warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:18:48noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 20:18:48warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:13:05warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:13:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:13:01noticeREGISTRATION COMPLETE - Waiting for Operational status
18-07-2023 08:12:56warningDynamic Range Window violation
18-07-2023 08:12:56warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:12:55warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:12:50noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:12:49noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:12:44warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:12:42noticeHonoring MDD; IP provisioning mode = IPv4
18-07-2023 08:12:27criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 08:00:01noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 07:57:39noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-07-2023 13:28:21noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-07-2023 13:28:21warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-07-2023 13:18:17warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-07-2023 13:18:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-07-2023 11:07:08warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Can you start from a clean sheet and do this..
_______________________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.
Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and any T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the PostRS and any T3 ones) you have a problem (noise) that only a Tech visit will sort.
Then if you havent already... set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
