Bhjc
  • 6
Message 1 of 7
Hub 5 Apple IMac issues
Our Mac worked fine with the old hub. Since we’ve had this one it’s a complete nightmare. I recently spent more than an hour on the phone to Apple and they tried various options but no joy.
when we try to connect to the wifi it doesn’t recognise the password. We’ve split to 2.5 and 5 but that doesn’t help. We’ve rebooted and reset everything but it still doesn’t work. We are having to hotspot on our phones and eat data to get it to work.
Help!
Tags (5)
  • 6.8K
  • 591
  • 1.78K
Message 2 of 7
Re: Hub 5 Apple IMac issues
Try settting the wifi to a legacy wifi setting as below;
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
If you still cannot get it connected, ask for your old Hub back.  It can and has been done for other users who have had issues with the Hub 5 ax wifi protocol
Bhjc
  • 6
Message 3 of 7
Thanks. Will give it a try.
Bhjc
  • 6
Message 4 of 7
Gareth_L
  • 11.49K
  • 635
  • 1.25K
Message 5 of 7
Hello Bhjc,
Quick message to see how you got on with the above advice?
Gareth_L
Bhjc
  • 6
Message 6 of 7
I’ve persevered and it’s still rubbish. I’m fed up of keep rebooting Mac and hub! Please help.
  • 35.09K
  • 3.41K
  • 6.68K
Message 7 of 7
Are you connecting it on wifi? If so try this as well.
_________________________________________
After a MacOS/iOS update, it may auto turn on Automatic Proxy Discovery for all Wi-Fi networks - so in MacOS turn it off in network settings as per message 7 (below).
In iOs go to Settings>WiFi> tap the blue”I” icon and scroll down and make sure Configure Proxy/‘ is set to off.
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-5-macOS-Monterey/td-p/4885920
