Dazzapfc
Message 1 of 8
Hub 5 - 2.4Ghz not showing
Just been upgraded to 1 gig broadband and sent the hub 5. I've installed it and is working fine on 5Ghz but I've a phone and lightbulbs that need 2.4Ghz. I've contacted Virgin who have split the network and on the connect app it shows as 5 & 2.4 but the 2.4 is not showing on the WiFi. I've changed its name etc. Any ideas? TIA.
  • 1.87K
  • 116
  • 432
Super solver
Message 2 of 8
Re: Hub 5 - 2.4Ghz not showing
"2.4 is not showing on the WiFi"
This exactly what I've been expecting to read for months. A super clear statement of a defect.
The Hub 5 WiFi is broken on many units, even with a split SSID operation on both bands is not possible with this Hub.
The only way to use a Hub 5 is in Modem mode with a 3rd party Router / own WiFi solution.
Dazzapfc
Message 3 of 8
Back in touch with virgin again tomorrow then and I'm guessing swap back to the hub 4
Kath_F
  • 34.74K
  • 1.34K
  • 2.81K
Message 4 of 8
Hi Dazzapfc,
We're sorry to hear you're having an issue with some of your devices not finding the network even when on a split band.
This can sometimes happen if the devices are incompatible with WiFi 6. The teams will be able to change the Hub back to a 4 for you or as suggested by Client62, you can opt to use the Hub 5 in Modem mode and connect your own third party router. If you're prefer the Hub 4, give the team a call on 150 / 0345 454 1111.
Keep us posted on how you get on.
Kath_F
Dazzapfc
Message 5 of 8
Thank you for your message.
They won't give me hub 4. I've spoke to 6 different people tonight even retention as I've had enough and want to leave then they hung up on me. Disgusting
  • 20.48K
  • 828
  • 2.2K
Message 6 of 8
VM just can't win people want hub 5 people want hub 4 people hate hub 5 people hate hub 4 just give up VM and start sending out modems only that work because they are simple like whats the worst that can happen you lose people? you lose people even with a bad hub.
Paul_DN
  • 10.7K
  • 546
  • 1.09K
Message 7 of 8
Hi Dazzapfc,
Thank you for reaching back out, I was able to locate you on our system with the details we have for you and can see you have spoken to us and a technician has been arranged, please let us know how things go.
Paul.
Dazzapfc
Message 8 of 8
We had an engineer come out today who spent over an hour trying to sort out the hub 5 but couldn't get it to work so ended up putting in a hub 4 and straight away everything worked perfectly and we still have the superfast speed. I just wish the guys online had listened to me and this could have been sorted earlier.
Thank you to Colin the engineer for sorting it out.
