cooperp76
  • 5
Hub 4
I received a hub 4 on the promise of better signal. Its been much worse, only has one connection point and links poorly with my extender. I didn't have any of these problems with hub 3.
I am told the signal is fine when I check but it keeps dropping out.
Any help gratefully received as all 'help' options on virgin site do not help. I also can't get through on phone line
Tags (1)
  • 16.27K
  • 710
  • 1.6K
Re: Hub 4
Router mode is not that good use it in modem mode and get a better wireless router with 1Gb ports.
Zoie_P
  • 2.91K
  • 137
  • 235
Re: Hub 4
Hi Cooperp76,
thanks for your post 🙂
Sorry to hear you are having issues with your HUB4,
I have located your account and can see there are some issues with your power levels that would require a technician
I will pop you over a PM and we can fo from there
Zoie
