Danadia
  • 6
Message 1 of 55
Hub 4
I am very disappointed with Hub 4. The internet falls few times a day and customer service is rubbish. I NEED to talk to somebody and get back Hub 3 or something.
I will stop the payments and maybe then somebody will bother to talk to me.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 55
Re: Hub 4
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
Then
Can you please
Hub 3 When the page appears DO NOT LOG IN but click ‘Check Router Status’.
If you withhold your payments they will send you a letter then probably put you on a credit blacklist, and there would start no end of problems.
Danadia
  • 6
Message 3 of 55
Re: Hub 4
Tried everything, the Hub is getting very hot to touch. Also it might be slow or falls on wireless.
I really don’t know what to do more.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 55
Re: Hub 4
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Danadia
  • 6
Message 5 of 55
Re: Hub 4
Thank you, I will try to call in the morning. All these problems started after I got the Hub 4. With Hub 3 worked well. ☹️
LindaRuth
  • 35
Message 6 of 55
Re: Hub 4
Interested to know how you get on. We are having loads of issues with Hub 4. Nothing works as it did before
Tags (1)
Danadia
  • 6
Message 7 of 55
Re: Hub 4
I got a new Hub 4 yesterday and will see. At the moment seems alright.
Danadia
  • 6
Message 8 of 55
Re: Hub 4
Also, my daughter used to play games and now she is home to Uni so I can’t really tested on games.
LindaRuth
  • 35
Message 9 of 55
Re: Hub 4
Was it straightforward when you called the helpline?
Danadia
  • 6
Message 10 of 55
Re: Hub 4
Wasn’t easy to get to talk to a human beeing. Only after someone here gave me a phone number I could get through. Anyway, as I said, my daughter used to play games and she went to uni so I can’t test it unless I start playing. Wish I have time for it.
