Just joined
Message 1 of 5
Hub 4 - wifi intermittent
Hi - I've reset my router and created 2 separate networks in my home for 2.4ghz and 5ghz channels but the connection keeps dropping from the 2 wifi boosters I have from Virgin Media. I've reset the router numerous times and called the second line support team for help on 4 occasions but they refuse to send a technician as the hub is showing from their perspective full connection to the router!
This is not the issue - it's the poor wifi from the router - can anyone help?
Thanks in advance.
  • 24.4K
  • 1.4K
  • 3.1K
Message 2 of 5
Re: Hub 4 - wifi intermittent
Put the hub into modem mode with your own router or mesh system.
They are correct that they cannot assist with WiFi issues.
Just joined
Message 3 of 5
Thanks Gary
  • 17.28K
  • 1.82K
  • 2.99K
Message 4 of 5
Thanks Gary - I dont have the Hub4 but if its like the Hub3 - did you disable "smart wifi" too?
Scan for the best (least congested/strongest) 2.4 channel  to use in the location and switch your channel to that (one of - 1,6, or 11)
  • 24.4K
  • 1.4K
  • 3.1K
Message 5 of 5
@jbrennand wrote:
I dont have the Hub4 but if its like the Hub3 - did you disable "smart wifi" too? And then scan for the best (least congested/strongest) 2.4 channel (1,6, or 11) to use in the location?
Thankfully there is no “smart” WiFi on the Hub4.
