  • 29
Message 21 of 28
Re: Hub 4 wifi dropping
Yes its still very bad. Its been going on a long time.
  • 25.14K
  • 1.44K
  • 3.2K
Message 22 of 28
How are wired connections?
  • 29
Message 23 of 28
I have a ps4 wired and it does not have any issues all my laptops and phones are WiFi only. Also my main TV box and TV are connected via earthnet and again no problems.
  • 25.14K
  • 1.44K
  • 3.2K
Message 24 of 28
So if you’ve optimised the Wi-Fi on the hub and it’s still doesn’t suit your requirements you’ll need to look into a mesh system or better standalone router
  • 29
Message 25 of 28
I have purchased a BT mesh system 3 disk. Also I have some plugs from virgin. I have tried everything. At this moment in time we have had to buy a tablet and put a virgin sim card in. This is the only way we can get a good WiFi signal.
  • 25.14K
  • 1.44K
  • 3.2K
Message 26 of 28
What was wrong with the BT system?
Which model did you buy?
  • 29
Message 27 of 28
Its the 3 disk kit BT WHOLE HOME  same problems wifi ok then nothing.
  • 25.14K
  • 1.44K
  • 3.2K
Message 28 of 28
Did you disable the hubs Wi-Fi output?
