  • 29
Message 11 of 28
Re: Hub 4 wifi dropping
Yes for the hub. Nothing else is connected
  • 25.14K
  • 1.44K
  • 3.2K
Message 12 of 28
Post the Network, Upstream and Downstream logs from the hubs admin pages
  • 29
Message 13 of 28
I can't find them on the new hub 4 layout what do I go into
  • 25.14K
  • 1.44K
  • 3.2K
Message 14 of 28
Login to the admin pages, go to Advanced Settings, Tools, Network Status
  • 29
Message 15 of 28
253310000005.00000038.605377QAM25625
11390000006.80000337.636276QAM2561
21470000006.19999737.636276QAM2562
31550000005.69999737.636276QAM2563
41630000005.30000338.605377QAM2564
51710000005.40000238.605377QAM2565
61790000005.50000038.605377QAM2566
71870000005.80000338.605377QAM2567
81950000005.90000238.605377QAM2568
92030000006.00000038.605377QAM2569
102110000006.00000038.983261QAM25610
112190000006.00000038.983261QAM25611
122270000006.00000038.983261QAM25612
132350000005.80000338.983261QAM25613
142430000005.80000338.605377QAM25614
152510000005.50000038.605377QAM25615
162590000005.69999738.605377QAM25616
172670000005.90000238.983261QAM25617
182750000005.69999738.605377QAM25618
192830000004.90000238.983261QAM25619
202910000004.19999738.605377QAM25620
212990000003.50000038.983261QAM25621
223070000004.09999838.605377QAM25622
233150000004.69999738.983261QAM25623
243230000005.09999838.983261QAM25624
263390000004.59999838.983261QAM25626
273470000004.19999738.983261QAM25627
283550000004.00000038.983261QAM25628
293630000003.50000038.983261QAM25629
303710000002.90000238.605377QAM25630
313790000003.00000038.605377QAM25631
3.0 Downstream channelsChannel Lock Status RxMER (dB) Pre RS Errors Post RS Errors
25Locked000
1Locked23162435540
2Locked6403652900
3Locked6221972820
4Locked6191404510
5Locked6227662010
6Locked6210701920
7Locked6199789600
8Locked5501875800
9Locked5491667700
10Locked5508507800
11Locked5475052500
12Locked5454118810
13Locked5446492200
14Locked5454069100
15Locked5468684300
16Locked5412897810
17Locked5481946000
18Locked5432483200
19Locked5401283900
20Locked5440341600
21Locked5411073300
22Locked4912190000
23Locked5445959900
24Locked6608652800
26Locked6608182800
27Locked6608418100
28Locked6582071700
29Locked6645019400
30Locked6595848900
31Locked9613607600
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159804K1560QAM4096392
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 3.5394541570
  • 29
Message 16 of 28
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13260000043.5205995120 KSym/sec64QAM7
22580000042.7705995120 KSym/sec64QAM8
33940000044.0205995120 KSym/sec64QAM6
44620000044.5205995120 KSym/sec64QAM5
3.0 Upstream channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
  • 29
Message 17 of 28
 this is what I get when I try do a speed test.
  • 29
Message 18 of 28
Hi do the figures look ok or do I need to do anything?
  • 12.27K
  • 950
  • 1.58K
Message 19 of 28
The Hub data looks OK.
The speed test needs redoing using  a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 1.82K
  • 105
  • 154
Message 20 of 28
Hi icemanmaz,
Thanks for your post and apologies for the delayed response. Are you still issues with your wifi connection? I'm unable to run remote diagnostics with your connection.
Cheers
Corey C
