esdsouza
Message 1 of 5
Hub 4 white light
I have recently installed the Hub 4.
Is there anyway that the white light on the Hub4 can be dimmed down. It is annoying as the hub is in my bedroom and lights up the whole room at night.. Can it be switched off so that it does not effect my sleep😩
lotharmat
  • 947
  • 70
  • 143
Well-informed
Message 2 of 5
Re: Hub 4 white light
I believe there is a setting in 'Advanced' somewhere!
gary_dexter
  • 30.65K
  • 1.9K
  • 4.07K
Message 3 of 5
Yes - go into the admin page and turn down the "light ring" brightness
esdsouza
Message 4 of 5
Thanks. I have changed the light ring setting and will check, tonight.
lotharmat
  • 947
  • 70
  • 143
Well-informed
Message 5 of 5
If that's too bright: Insulating tape! 😉
