on 21-12-2021 15:59
I have had a hub4 since early October, in the first couple of weeks it reset to the default 4 or 5 times since then once at the end of November and again today. This only happens on 2.5GHZ, 5GHZ OK. This appears as other users reported to be a Firmware/Software issue, related to updates?
on 21-12-2021 19:44
Is there a question here?
on 23-12-2021 20:58
Hi Davids73,
Thank you for your post and welcome to the community.
I'm very sorry for any issues you've been having with your broadband.
To confirm are you saying the hub is factory resetting?
^Martin
on 24-12-2021 14:15
Yes Hub resets 2.5GHz channel back to default setting no issues with 5GHz channel.
on 24-12-2021 15:57
If you have not got the pods then turn off smart/Intelligent WiFi.
on 27-12-2021 10:49
Hi Davids73, thanks for the message and sorry to hear that the hub 4 keeps resetting. Does the same happen following a pin hole reset? Can you confirm if you are still getting this issue since posting? - Chris
on 27-12-2021 14:26
It has been working fine since rest name and password (since 21/12/2021)
on 29-12-2021 14:38
Hi @Davids73
That is great to hear and thank you for letting us know!
Please don't hesitate to reach out should you need any assistance in the future.
Thank you.
