Hub 4 problem
Hi, Since I "upgraded" my Hub last week, WiFi has been shockingly awful. It keeps coming in and out and my partner works from home, calling people using the internet. Why is it so intermittent? Apparently there's nothing wrong with the Network and I have rebooted the hub but it's still intermittent. I can't even talk to a Human today! I've made a complaint to the company but is there a problem with my box? No clue how to solve this.
  • 11.9K
  • 927
  • 1.53K
Re: Hub 4 problem
Mike Robinson
  • 11.9K
  • 927
  • 1.53K
Re: Hub 4 problem
Can you please
Mike Robinson
  • 24.77K
  • 1.43K
  • 3.15K
Re: Hub 4 problem
What are your wired connections like?
Re: Hub 4 problem
Hi, I don't know where to paste the direct live link. I don't have a camera icon or chain link anywhere that I can see.
  • 3.62K
  • 215
  • 277
Re: Hub 4 problem
Hi Zlseekings,
Thanks for posting and welcome to our community 🙂
I'm sorry to hear you're having some issues with the WiFi, I've been able to locate your account using your forum details, and can see you were able to speak to an agent who advised there was an area issue.
This does now look to be resolved, if you are still experiencing issues please let us know.
Alex_Rm
