on 27-05-2021 21:36
Just literally got my Hub 4 after loads of issues with Hub 3 dropping signal etc on wifi.
So I had ALL of my devices named and assigned IP addresses on the hub 3 - that was a right palava as it was SO BUGGY.... well it seems the Hub 4 is EVEN WORSE!!!
Some of my device names save - some don't. Sometimes I name one, and it changes another to that name. Sometimes I name one and it seems to work, then suddenly it's back to its self assigned name, or even one of the others I assigned!!
I mean WTH.... Do Virgin not test anything before releasing it?
on 28-05-2021 08:53
on 28-05-2021 09:18
That’s why they put modem mode in.
That way you can use your own better equipment that “works”.
on 28-05-2021 09:44
I know I CAN do that, but why should I HAVE to?
They've just repeated the same mistake... If we keep letting them off the hook they'll keep doing it!
on 28-05-2021 10:45
@adamelphick wrote:I know I CAN do that, but why should I HAVE to?
Because your unhappy.
on 28-05-2021 16:25
Yea but that's not the point... Equipment they supply should work! Surely?
on 28-05-2021 17:07
@adamelphick wrote:Yea but that's not the point... Equipment they supply should work! Surely?
Does it provide you with internet access?
Then it’s working.
28-05-2021 17:34 - edited 28-05-2021 17:36
But being a not impotent feature VM will not fix something that they don't think is impotent for full internet access and the people added this knows that, VM don't support port forwarding and because NAT is not 100% for router mode there needed to be modem mode that supports everything even if it is just for one WAN IP. Really just how much can VM remove from the hubs for it to pass most stuff and making the user get their own router, its likely this feature will be removed in the next hub.
on 28-05-2021 18:44
I still think it is very bad practice indeed.
I can't understand why they would CREATE a function that doesn't work - why have it there at all? It's like people are willing to let them off the hook just because they can circumvent it with other hardware - at cost!
If you'd bought a router that had that function and it didn't work you would be sending it back or demanding a replacement surely? We are in effect buying this Hub, it is invariably subsidised by the cost of the internet connection.. it's not as if Virgin are giving it to us from the goodness of their hearts is it?
HOW ABOUT A COMMENT VIRGIN? I AM SURE SOMEONE FROM YOUR COMPANY READS THESE THREADS!!!
Don't get me wrong - I love the speed etc of Virgin connections, and don;t have issues that often, but honestly do they care about their customers? I worry not.... When I did my upgrade the guy told me my account with them had been active for 21 years!! I mean surely loyalty should count for something - and to be fair even new customers should get equipment that actually functions as it is supposed to do!
28-05-2021 18:51 - edited 28-05-2021 18:53
@adamelphick wrote:...but honestly do they care about their customers?
Yes they gave us modem mode and technically thats all they should give us doing a router mode with wifi was a bonus.
on 28-05-2021 18:55
The hub costs £30 to make. If that. So it’s negligible in terms of cost.
