@Nedular wrote:
<snip> I have installed a few Ubiguiti networks where i have had zero problems with WIFI.
You have answered your own dilemma 🙂 However you will never get an ISP supplied router, to match anything Ubiquiti produce, as the Hub is built to be as cheap as possible for mass installations. I would suggest an AC Pro, strategically placed would give a good result.
