k9sar
  • 6
Hub 4 modem mode with Unifi USG 3
I have a couple of questions regarding the above setup which I would appreciate some help with.
Currently I use a USG 3 with a LAN 192.168.5.0/24 and the WAN side is connected to a BT G-Fast modem and configured for PPPOE
Next week I move to VM so instead will connect to a Hub 4 which I will plan to put into modem mode and then reconfigure the WAN on the USG 3 to DHCP.
So my questions are:-
  • USG 3 vs Hub 4 for as a router, should I just use the Hub 4 for routing and forget the USG 3?
  • If I use the USG 3 with the LAN configured 192.168.5.0/24 will I be able to access the Hub 4 console on 192.168.100.1
  • With the USG 3 WAN configured for DHCP can I just leave the DNS entries empty and it gets these from VM via DHCP?
I think that is all for now, thanks in anticipation.
  • 16.28K
  • 711
  • 1.6K
Re: Hub 4 modem mode with Unifi USG 3
no
yes
yes
  • 3.19K
  • 249
  • 694
@k9sar wrote:
<snip>
<snip>
1 - Yes to modem mode.
2 - Yes you should be able to.  However sometimes it may take a few attempts.
3 - No, I would not recommend using VM's own DNS servers.  Better to go for Google, OpenDNS or Quad 9.  They are more reliable.
