Hello,
For the past decade or so I have been running a Virgin connection with the hub in modem mode connected to a pfsense firewall. For the most part, my setup has was working fine on the 200 Mb/s service with a Hub 2ac for a fair few years. I upgraded on the 18th of January to the 500 Mb/s service with a Hub 3 and this was also working fine. The problems started on the 26th of January when I was upgraded to Gig1 with a Hub 4 as a Volt benefit.
Since then, I am having a regular issues with SSL traffic to *some* destinations breaking when the Hub 4 is in modem mode. In Firefox, this manifests as the browser hanging on "Performing TLS Handshake" until it times out. In Chrome it hangs on "Establishing Secure Connection".
Some of the problem sites include:
When the problem occurs, I also have issues tunneling traffic (e.g. remote desktop) over SSH. Other websites (e.g. https://old.reddit.com and https://www.speedtest.net ) and anything routed over my Hurricane Electric IPv6 tunnel continue to work absolutely fine. Online game traffic (CS:Go, Tarkov, etc.) also seems to be unaffected. Speed tests continue to report the full expected speed.
Pings to the problem sites continue to work. Even the redirect from news.bbc.co.uk to www.bbc.co.uk/news works, the browser just hangs after the redirect.
Sometimes the problem is transient and resolves itself after a few minutes. Other times it takes a reboot of the Hub 4 to resolve. Rebooting the firewall does not resolve the issue and the issue occurs with other devices (including an alternative router and a straight Windows desktop) in place of the firewall.
Packet captures show that the traffic is correctly leaving the firewall's WAN interface.
Also, the admin interface for the Hub 4 at 192.168.100.1 stops responding within an hour or two of rebooting the hub. Ping to the hub also become sporadic with only one in every ten or 20 pings eliciting a response. It takes a reboot of the Hub 4 to regain access to the admin interface.
The issues (including the admin interface one) do not occur if I introduce a double-NAT scenario with the Hub 4 in "normal" mode with the firewall in the DMZ. Obviously this is not an ideal long-term solution.
Has anyone else come across this? is it a "feature" of the Hub 4 or have I just got a bad one?
I am dreading trying to explain this to support over the phone as it is an intermittent issue and involves modem mode.
