captaincallum
  • 8
Message 1 of 12
Hub 4 keeps rebooting about once per hour
I happen to have the Hub 4 in eyesight when I'm at my desk and the white light goes off for a second or two - then it comes on BRIGHT before settling down within 5 seconds back to normal.
I didn't think anything of it until I was on a Zoom call last night and the other folks worked out with me that I really do lose about 5 seconds of connectivity a few times per day. Not normally an issue however I'm a small-time YouTuber and I've just realised my live streams will be affected.
Anyway, is this just a factory reset thing do you think..?
C.
  • 35.09K
  • 3.41K
  • 6.68K
Message 2 of 12
Re: Hub 4 keeps rebooting about once per hour
Lets look at the connection data - can you do this...
____________________________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return -- log in and then Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
captaincallum
  • 8
Message 3 of 12
John, I do hope they give you a gold star periodically!
DATA SET #1
3.0 Downstream channels
92030000000.936.6QAM2569
4163000000236.6QAM2564
51710000001.836.6QAM2565
61790000001.736.6QAM2566
71870000001.637.6QAM2567
81950000001.336.6QAM2568
102110000000.736.6QAM25610
112190000000.736.6QAM25611
122270000000.436.4QAM25612
132350000000.136.6QAM25613
14243000000-0.336.4QAM25614
15251000000-0.735.6QAM25615
16259000000-1.335.8QAM25616
17267000000-1.135.8QAM25617
18275000000-0.336.4QAM25618
19283000000-0.136.4QAM25619
202910000000.136.4QAM25620
21299000000-0.336.6QAM25621
22307000000-0.636.6QAM25622
23315000000-0.437.4QAM25623
24323000000-0.137.4QAM25624
253310000000.136.6QAM25625
26339000000-0.237.4QAM25626
27347000000-0.636.6QAM25627
28355000000-0.636.6QAM25628
29363000000-136.6QAM25629
30371000000-1.436.6QAM25630
31379000000-1.436.6QAM25631
32387000000-1.636.4QAM25632
33395000000-1.736.4QAM25633
34403000000-1.636.6QAM25634
captaincallum
  • 8
Message 4 of 12
DATA SET #2
9Locked36.60965300
4Locked36.60965300
5Locked36.60965300
6Locked36.60965300
7Locked37.63627600
8Locked36.60965300
10Locked36.60965300
11Locked36.60965300
12Locked36.38689000
13Locked36.60965300
14Locked36.38689000
15Locked35.59507800
16Locked35.77991100
17Locked35.77991100
18Locked36.38689000
19Locked36.38689000
20Locked36.38689000
21Locked36.60965300
22Locked36.60965300
23Locked37.35598800
24Locked37.35598800
25Locked36.60965300
26Locked37.35598800
27Locked36.60965300
28Locked36.60965300
29Locked36.60965300
30Locked36.60965300
31Locked36.60965300
32Locked36.38689000
33Locked36.38689000
34Locked36.60965300
captaincallum
  • 8
Message 5 of 12
More on DOWNSTREAM:
3.1 Downstream channels
159964K1840QAM4096759
159Locked37-7.3284209024817728
captaincallum
  • 8
Message 6 of 12
UPSTREAM DATA SET:
3.0 Upstream channels
143100000395120 KSym/secQAM642
223600000425120 KSym/secQAM645
33010000040.55120 KSym/secQAM644
436600000405120 KSym/secQAM643
549600000395120 KSym/secQAM641
3ATDMA0000
4ATDMA0000
5ATDMA0000
3.1 Upstream channels
610.033.22KQAM8
6OFDMA20053.940
captaincallum
  • 8
Message 7 of 12
  • 20.48K
  • 828
  • 2.2K
Message 8 of 12
clipping...this in router mode?
captaincallum
  • 8
Message 9 of 12
Hey - thanks for showing interst..!
I have it working "out the box" not in any special way. I'm connecting all my "stuff" via ethernet on a local switch on my desk - the rest of the family connect via wifi. I have a Ubiquity access point - also connected via Ethernet on the other side of the house - so both wifi points are working independently.
C.
captaincallum
  • 8
Message 10 of 12
PS - Not sure what "clipping" means.. Is that what you are seeing? I am an audio guy actually, so I assume it's meant in a similar way..
C.
