Hub 4 keeps dropping out
We have a hub 4 and most evenings the Internet drops out and the lights on the STB shows 2 white arrows. Sometimes it happens 2 or 3 times in an evening.
Can anyone suggest what the problem may be and a solution.
Many thanks.
Neil
  • 11.57K
  • 898
  • 1.48K
Re: Hub 4 keeps dropping out
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Thanks Mike. Rebooted just now 10:00am sunday morning. Will let you know if it helps.
  • 11.57K
  • 898
  • 1.48K
Also ...
Mike Robinson
