  • 17
Message 1 of 29
Hub 4, keep loosing connection
Hello There,
So I installed hub 4,  3 days ago and have constant connection drop .. can you anyone help?
Have done a few 10 min resets etc ..
3.0 Downstream channels
25Locked0890
4Locked10901829700
5Locked13142687410
6Locked12888017700
7Locked10963256600
8Locked285641968500
9Locked16984578720
10Locked829532800
11Locked661651030
12Locked667505320
13Locked940714760
14Locked1008032720
15Locked262061920780
16Locked6225833100
17Locked8834328130
18Locked9178682160
19Locked6882063240
20Locked6651822350
21Locked8969726330
22Locked7671834380
23Locked6888394470
24Locked12043621570
26Locked12662116820
27Locked10303871820
28Locked2492528382930
29Locked117847421490
30Locked125127881470
31Locked101478021970
32Locked88934112150
33Locked119746782140
34Locked1932584262450
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
35Locked 5.2754900410
3.0 Upstream channels
1US_TYPE_STDMA0010
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0010
  • 8
Message 2 of 29
Re: Hub 4, keep loosing connection
apparently the answer is: don't install a hub 4!
  • 12.3K
  • 952
  • 1.58K
Message 3 of 29
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 17
Message 4 of 29
Yeah but it is a bit late for that option ....
D.
  • 17
Message 5 of 29
Hi Mike,
I have checked 0800 number and all seems okay on their side although earlier on in the week there was some apparent issues that were resolved... I will report back this afternoon when back home.
D.
  • 17
Message 6 of 29
Mike,
Link attached as well as other info requested..
On Airport Utility on Mac I can see that tab (Internet) which is HUB4 is often disconnected..
But also when I run Network Diagnostics Tool all seems okay with some problems with WI-FI but nothing specific ... also I had this network for a few years..
HUB 4 in router mode, TC in bridge mode ..
https://www.thinkbroadband.com/broadband/monitoring/quality/share/27d9b86af9be5b86118897dabc05a34bc1...
Help.
253310000006.00000040.366287QAM25625
41630000005.50000040.366287QAM2564
51710000005.50000040.366287QAM2565
61790000005.30000340.946209QAM2566
71870000004.90000240.366287QAM2567
81950000005.19999740.946209QAM2568
92030000005.50000040.946209QAM2569
102110000005.59999840.366287QAM25610
112190000005.90000240.946209QAM25611
122270000006.00000040.366287QAM25612
132350000006.09999840.366287QAM25613
142430000006.40000240.366287QAM25614
152510000006.30000340.946209QAM25615
162590000006.09999840.366287QAM25616
172670000005.59999840.366287QAM25617
182750000005.50000040.366287QAM25618
192830000004.90000240.946209QAM25619
202910000004.59999840.366287QAM25620
212990000006.00000040.366287QAM25621
223070000006.50000040.366287QAM25622
233150000006.30000340.366287QAM25623
243230000006.69999740.946209QAM25624
263390000005.90000240.366287QAM25626
273470000006.50000040.366287QAM25627
283550000006.00000040.366287QAM25628
293630000005.19999738.605377QAM25629
303710000005.50000038.983261QAM25630
313790000005.09999838.605377QAM25631
323870000005.00000038.983261QAM25632
333950000006.00000040.366287QAM25633
344030000006.80000338.983261QAM25634
  • 17
Message 7 of 29
25Locked060
4Locked16737454800
5Locked19126707000
6Locked19227622100
7Locked16398687600
8Locked21038643900
9Locked24993483700
10Locked1209358300
11Locked954837110
12Locked190535855900
13Locked1167771600
14Locked1102349520
15Locked966535410
16Locked190025121810
17Locked1278424600
18Locked1214299000
19Locked183171808600
20Locked173713814540
21Locked1205585120
22Locked1043623450
23Locked923115420
24Locked1646487120
26Locked1623202050
27Locked1342274160
28Locked1322953330
29Locked1672120180
30Locked1597871980
31Locked12972980110
32Locked14156495160
33Locked16133513120
34Locked141212603160
  3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
35964K1880QAM4096759
35Locked 5.11724769391
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13260000049.2705995120 KSym/sec64QAM9
23940000048.5205995120 KSym/sec64QAM8
34620000048.7705995120 KSym/sec64QAM7
45370000048.7705995120 KSym/sec64QAM6
TIMEOUTS HERE SEEMS TO BE CHANGING BETWEEN T3 and T4
3.0 Upstream channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0001
2US_TYPE_STDMA0001
3US_TYPE_STDMA0001
4US_TYPE_STDMA0001
Thu 01/01/1970 00:01:173No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 18/10/2020 12:37:365MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 18/10/2020 12:40:366SW Download INIT - Via Config file cmreg-vmdg640-bbt062-b.cm
Sun 18/10/2020 12:41:526SW download Successful - Via Config file
Sun 18/10/2020 12:44:255MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 18/10/2020 12:55:285MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 18/10/2020 13:16:184DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 19/10/2020 06:52:445MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 05:37:195RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 05:37:406CM-STATUS message sent. Event Type Code: 5; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 09:22:513No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 04:08:136CM-STATUS message sent. Event Type Code: 23; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 15:22:355MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 15:22:443Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 15:22:465RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 15:23:016CM-STATUS message sent. Event Type Code: 4; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 17
Message 8 of 29
Guys,
Is there anyone who can help to resolve issue with disappearing internet connection ?  All seems to be okay after hub reset for 10-15 min then again it drops and reconnects as it wants and when it wants.. Tried mobile message service but no reply, reported all what I was asked for here , no reply...
Time to change provider?  Pain in the bottom especially all was fine on HUB3 and never had issues...
Now Hub 3 is not connecting anymore and its a shame as I would send back HUB 4 to VM with no delay !
  • 25.21K
  • 1.45K
  • 3.21K
Message 9 of 29
You need to call in or wait the 5-7 say response time from a forum mod
  • 17
Message 10 of 29
I see okay I didnt know it is 5-7 days wait time... thanks for letting me know !
D.
