Hub 4 hot on top (just installed)
Jehh
Hub installed yesterday, and noticed it's hot on the top. Can't hear a fan. Concerned that it is a fire risk. Any suggestions?
1 ACCEPTED SOLUTION
Accepted Solutions
Legend
Login to the Hub 4 at http://192.168.0.1/  use the HUB Password from the label on the bottom ( not the Wi-Fi password ).
Does the Hub 4 have Diagnostics that report if the Temperature as Normal or Too Hot ?
6 REPLIES 6
Legend
Jehh
Thanks! Have run diagnostics and they have returned 'some problems'. One of the suggestions was to check if the hub is hot.
Legend
On a Hub 3 if I scroll down through the Diagnostics results list there is a " Temperature Normal / Too Hot " response.
Customer Support are on 150 or 0345 454 1111 from a non-VM phone.
Report the Hub as overheating, fan not working.
Good Afternoon @Jehh, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the Hub 4 being hot on the top of the router.
Can you please confirm if the light is currently a solid red, or if this is expected solid white light?
David_Bn
It's a solid white light. I'm now on the phone to the helpdesk, so hopefully will get this resolved. Thank you!
Thanks @Jehh.
Do please feel free to keep us updated on how the call goes, and we'll look into this further, if this is required.
Kindest regards,
David_Bn
