Hub 4 - ethernet status lights?
Hassan69
Hi does the Hub 4 have status lights on Ethernet ports. Only asking as I had issues with connecting my laptop to the hub and had no internet access. It’s working now.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi, i got it sorted by fixing the ethernet properties. I've turned off the WiFi since fixing it and so far no drop connections with using the cable😀. As my previous Hub 3 wouldn't stay on ethernet connection long enough, only for a second or so.
3 REPLIES 3
Paul_DN
Hi Hassan69,
Thank you for reaching out to us in our community and welcome, sorry to hear you were facing issues with your Laptop Via a wired connection, I can advised the Hub 4.0 doesn't have lights on the Ethernet ports indicating if the device is connected.
I was able to locate you on our system with the details we have for you, you advised this has now started working, as I cannot  see any issues, what was  the reason and how did you resolve it?
Paul.
Hi @Hassan69 thanks for your reply, that's great news!
If you do need any further help then please don't hesitate to let us know 😊
Many thanks
Tom_W
