  • 6
Message 1 of 12
Hub 4 drop out
I recently upgraded to the hub 4. In the last 3 weeks I have had to restart it more than 10 times. I can also see from my security camera that it drops out for 1-2 hours at a time at night.
Once it is on it works fine for both WiFi and wired connection.
Any suggestions what I can do to correct? Or go back to my old hub. It needed probably 10 restarts in 4 years.
Thanks in advance for your help.
  • 24.31K
  • 1.39K
  • 3.09K
Message 2 of 12
Re: Hub 4 drop out
What drops out exactly?
  • 14.72K
  • 620
  • 1.42K
Message 3 of 12
Re: Hub 4 drop out
Hub 4 works best in modem mode then get your own wireless router with 1Gb ports.
  • 6
Message 4 of 12
Re: Hub 4 drop out
My Internet dies. My phone says 'connected without Internet'
  • 6
Message 5 of 12
Re: Hub 4 drop out
I'll try modem mode. I've got Google wifi hubs.
  • 24.31K
  • 1.39K
  • 3.09K
Message 6 of 12
Re: Hub 4 drop out
Connected to the hub already?
  • 6
Message 7 of 12
Re: Hub 4 drop out
Yeah my virgin hub was connected to my Google mesh. I've switched the virgin hub to modem mode. I'll monitor over the next few days and see what happens.
  • 24.31K
  • 1.39K
  • 3.09K
Message 8 of 12
Re: Hub 4 drop out
If you left the hub in router mode with the Google Wi-Fi nodes and also running in router mode that’s likely that causes the dropouts
  • 6
Message 9 of 12
Re: Hub 4 drop out
Does modem mode kill the wired connection? The tivo box says it is not connected when I can see the cables is plugged in.
  • 11.36K
  • 888
  • 1.45K
Message 10 of 12
Re: Hub 4 drop out
Modem Mode only has one active ethernet port on the Hub, if you need more than one port look at getting an unmanaged / simple >> switch << to use.
In Modem Mode the Hub has no routing facilities.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
