Jrack11
  • 11
Message 1 of 7
Hub 4 connection issues: some devices not connecting
Have had a hub 4 now for about 2/3 months and its been fine until past few days. Two different devices (an apple product and a samsung product) have both suddenly lost connection to wifi. Neither have had updates or anything, working fine evening, by morning neither could connect.
I have tried different fixes found online, restarting hub, forgetting connection and reconnecting, changing some connection settings, running diagnostic etc but nothing has worked. I would expect the problem to have been the device, had it not happened with two different makes of device, within days of one another. The messages I get on samsung device is that DHCP look up failed. I followed some online advice to correct it, but nothing has been successful.
Connection (to date) perfectly fine with other devices connected to wifi.
Any help or advice would be greatly appreciated.
Tags (1)
ShaunM1
Just joined
Message 2 of 7
Re: Hub 4 connection issues: some devices not connecting
I have the exact same issue started on Friday, logged on the lap top to work and no internet same fault description and searching for IP address. Been on the phone for 3 days now trying to sort.
Jrack11
  • 11
Message 3 of 7
Thanks for sharing, please let me know if you get anywhere with them over a fix.🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 7
May I suggest that you download and install a Wi-Fi analyser to show if there are any foreign Wi-Fi broadcasts interfering with your own Wi-Fi signals and where there are poor signal strengths..
From there you can look at refining your own Wi-Fi broadcasts.
I use this one ...
WiFi Analyzer Premium - Apps on Google Play
wifi-2
Jrack11
  • 11
Message 5 of 7
Thanks for this. I've checked and mine seems to have the channels to itself.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 7
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Jrack11
  • 11
Message 7 of 7
Not sure if this means anything but devices are able to connect to other wifi networks and also through hotspots with no issues.
As I said this is only an issue with 2 different devices, we have 10 others currently connected, again not sure if this is relevant in any way.
Thanks.
