on 26-03-2021 18:42
Hi there!
Ive recently been upgraded to the Hub 4. Really enjoying it. Much better speeds and signal strength throughout the home now the issue! I’ve changed my SSID’s (WiFi name and passwords) over to my own personal ones and separated them 2.4 and 5ghz. Now it keeps on changing the 2.4ghz back to the original. When I’ve logged into the settings page the up time is a low time meaning that it’s rebooting its self and changing ONLY the 2.4 back to the original. Bad thing is my home security is on the 2.4 so it’s all being disconnected without me realising.
I understand the most common answer being I should just use the default SSID for the 2.4 but I’ve got a ton of smart home devices so they’ll have to be setup again so looking for an easy fix.
Anyone else experienced this?
Thanks for reading!
on 14-09-2022 15:18
on 16-09-2022 15:53
Hi @Sparkly3366,
Thanks for providing the update on your latest Technician visit. I'm glad to hear they have been able to get things sorted for you, and you're now seeing a stable service, without the previous issues you've mentioned.
If you need anything else, please let us know and one of our team/community will be happy to help out.
Cheers,
on 16-09-2022 16:35
How come the “forum team” only ever reply to generally positive comments? No word form them on why some are able to request the hub 5 but others get fobbed off.
on 16-09-2022 17:06
on 16-09-2022 17:22
Does the Hub5 support the current Smart Wifi pods (hexagon shape)? The whole reason for me changing from the old Hub3 to Hub4 was for improved wifi - then I am told by staff I have to disable Smart Wifi on the router to combat the SSID naming issue. Thus, my wifi is poor and has been since the start of this thread nearly.
on 05-02-2023 15:05
Hello everyone,
I have got the same problem. After each reset the hub keeps changing SSID back to default. Weirdly it does that only for the 2.4ghz, not the 5.0… really annoying, and I would like to have this resolved. I have done factory reset few days ago, but the issue persists. Please let me know what can be done about this. Thank you
on 07-02-2023 16:11
Hi there @luksmo
Thank you so much for your post and we are so sorry to hear that you are facing these issues.
Just to confirm, does this happen when you reboot or when you perform a full factory reset by pushing into the 'reset' hole at the back of the Hub?
on 07-02-2023 16:18
Hello. Thank you for your reply. This happens when I reboot the hub (or when the hub reboots itself for some reason). Thank you
on 09-02-2023 18:20
Thank you for your reply luksmo.
So to clarify, you are not resetting your Hub to the default settings but rebooting it via the power and when you are doing this, it resets your 2.4Ghz SSID, is this correct?
on 09-02-2023 18:27
Yes this is correct. I have made one reset to the hub hoping it’s going to fix the issue, but it did not. After each reboot the hub is changing the SSID to the default one. I believe it’s faulty.
