on 08-12-2020 10:58
Hi All,
I've just upgraded to Hub 4 and 1Gig service. It's early days yet and I'm giving the system chance to bed down before I pass judgement on it.
I have a novice question on WiFi. I have some smart plugs that will only connect to 2.4GHz signal. Connecting them to WiFi has been problematic in the past and they frequently 'fall of' the WiFi altogether, despite being right next to the Hub (3). Should I separate out (rename) the individual 2.4 and 5.0 speeds to ease connection? If I keep them under the one name, does that affect the ability of the smart plugs to connect?
Also, I have a VM WiFi booster. With the Hub 3, it separated out the 2.4GHz and 5.0GHz signals. When upstairs on the opposite side of the house to the Hub but right next to the booster I could connect to the 5.0 GHz broadcast and get very good performance. With the Hub 4 they're no longer showing up as two separate signals as presumably they are both going under the same SSID?
Thanks in advance.
Answered! Go to Answer
on 07-06-2021 11:32
I did a search some time ago for my daughter, who is on BT, and there were lots of problems reported with Ring devices on various ISPs.
on 14-05-2022 17:30
Hi, how did you manage to split the broadcasts? I can only see one renaming possibility on VM hub4?
