Archerr
Hub 4 and Deco mesh system
I am a luddite with absolutely ZERO tech knowledge trying to reinstall my Deco S4 mesh system to the Virgin Hub 4 so my son can play games upstairs. I managed to connect it in my old house but then Virgin delivered a new Hub plus we moved. Now I have no idea how I did it before. Can someone bear to walk me through it as if they’re talking to someone with learning difficulties? For starters, how do I know how to switch the Hub off modem mode or to disable the back-up battery (if there is one) as the Deco instructions demand...? I’ve literally fallen at the first hurdle 😶
gary_dexter
  • 30.6K
  • 1.9K
  • 4.07K
Re: Hub 4 and Deco mesh system
Put the hub into modem mode. Allow it 5 minutes then power it off.
Connect the first deco node to the hub.
Power the hub on and wait 5 minutes.
Power on the deco and wait 5 minutes.
  • 22.51K
  • 2.41K
  • 4.02K
As Gary says - but make sure the first Deco is set to be in "DHCP&Nat mode" it will be in the settings somewhere - app or instructions should help do that - it "may" be preset that way anyway
Andrew-G
  • 6.19K
  • 1.09K
  • 2.63K
https://www.virginmedia.com/help/virgin-media-hub-modem-mode#hub3orhub4
Then follow the Deco instructions (if they've gone missing there's loads of help on the TP-LInk web site, with how to videos, FAQs and downloadable instructions.
