Craigjmackenzie
  • 6
Message 1 of 14
Hub 4 & WiFi plugs
hi
I got the hub 4 today and my WiFi plugs aren't working. They work on the 2.2ghz range so I've separated out the SSIDs however my plugs just aren't connecting. Seeing as they still do on the hub 3 so the issue is with the hub 4. Anyone know how I can sort this?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 14
Re: Hub 4 & WiFi plugs
Did you reset the Boosters to remove all the old settings (Hub 3) ?
Craigjmackenzie
  • 6
Message 3 of 14
It's not a booster. It's a WiFi plug. I can remotely control the power for whatever is plugged into it. There's no way to reset them, you just set them up again if there's a change to the WiFi
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 14
What make and model are the Wi-Fi plugs ?
Craigjmackenzie
  • 6
Message 5 of 14
Some random Chinese one called teckin off Amazon
https://smile.amazon.co.uk/dp/B07MQYN1K4/ref=cm_sw_r_cp_apa_i_RmPsFb9NTMKC6
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 14
Try switching the 5GHz off until they are connected to the 2.4GHz broadcast.
jhuk
  • 2.96K
  • 51
  • 275
Problem sorter
Message 7 of 14
All I know is the HUB4 is not yet supported by the VM Connect App which is used to find WIFI blackspots and set up your VM WIFI Boosters.
So possibly something is not ready in the HUB4 for any WIFI boosters to be connected but TBH no clue as never needed or tried on either HUB's.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 14
They aren't boosters, they are Wi-Fi controlled mains socket adaptors.
Craigjmackenzie
  • 6
Message 9 of 14
Although it's not a booster I think they might use a similar method of connecting or something which would explain why it doesn't work. I might go back to the hub 3 until they sort it
Craigjmackenzie
  • 6
Message 10 of 14
Tried this and it still doesn't work. I think it might be the same reason the boosters don't work ATM. Gonna go back to the hub 3 until they sort out the connectivity issues
