  • 8
Message 1 of 18
Hub 4 Wifi Range
I received & installed my Hub 4 this week, however the Wifi range seems to be very poor. One of my upstairs rooms hardly gets a signal, so I tried to use a signal booster (which I had previously used with my Hub 3). This shows a strong signal in that room, but no internet access. Can anyone explain this to me?
  • 11.31K
  • 887
  • 1.44K
Message 2 of 18
Re: Hub 4 Wifi Range
Can you get internet access using an ethernet cable connected device ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.28K
  • 1.39K
  • 3.09K
Message 3 of 18
You’ll need to reset and re-pair the booster to the new hub.
  • 8
Message 4 of 18
Yes, the cabled connections have a great signal.
  • 8
Message 5 of 18
I have done both & it still shows no internet
  • 24.28K
  • 1.39K
  • 3.09K
Message 6 of 18
Is it a Virgin supplied booster?
  • 8
Message 7 of 18
No, it's TP Link booster. I can get through to Virgin to get a booster.
  • 24.28K
  • 1.39K
  • 3.09K
Message 8 of 18
What model of booster?
Don't use the Virgin ones they’re worse.
Message 9 of 18
What booster do you suggest
  • 24.28K
  • 1.39K
  • 3.09K
Message 10 of 18
Not a booster. Either look into a better router or a mesh system.
