Hub 4 WiFi signal drops several times a day
Since connecting a new Hub 4 a month ago the signal drops several times a day for about one minute at a time. This is severely impacting my work.
i have tried resetting/ checking connections/all standard advice which has not resolved the problem
i also find it unsatisfactory that I cannot speak to somebody about this service problem
  • 24.94K
  • 1.44K
  • 3.17K
Re: Hub 4 WiFi signal drops several times a day
Do wired connections also drop?
I am not able to check this. However it is not a capacity issue due to too many devices or high use. It is a signal issue.
I need virgin media to investigate please.
  • 12.06K
  • 939
  • 1.54K
Mike Robinson
  • 12.06K
  • 939
  • 1.54K
Can you please
Mike Robinson
  • 24.94K
  • 1.44K
  • 3.17K
Based on what conclusions?
