crazypom1
  • 16
Hub 4 WiFi dropping
Good evening, my hub 4 keeping dropping WiFi , only way of returning it is the old power off and on trick. Surely this is not acceptable. Is there a fix for this ?
thanks in advance
Tags (1)
g0akc
  • 626
  • 63
  • 123
Rising star
Re: Hub 4 WiFi dropping
Ultimately get your own router and use hub in modem mode.
Check for neighbouring hubs etc. first. Use an analyser app and so on.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
crazypom1
  • 16
Thanks for taking time to reply, but does this not confirm that the equipment I have been sent to use is not fit for purpose.
