Edward036
  • 34
Message 21 of 43
Re: Hub 4 WiFi & hardwire intermittent issues
Ah, okay, thank you
Edward036
  • 34
Message 22 of 43
ihsaan96
  • 10
Message 23 of 43
I've got the same exact issue with Hub 4
Seems like it's hardware/firmware related
Edward036
  • 34
Message 24 of 43
Oh!! Has it been resolved? How did you know?!? Thx
Edward036
  • 34
Message 25 of 43
Mind you, I upgraded from 500mb to the 1g as I was having similar issues and put it down to needing more bandwidth due to high usage, streaming, gaming etc
So upgraded from Hub 3 to hub 4 and the issue continued.
ihsaan96
  • 10
Message 26 of 43
Not been resolved yet haha, I got upgraded from 100mb to 1Gb and since fitting the Hub 4, Ethernet straight to the Hub 4 gives me 270mb max download, WiFi gives me max 400mb download. All devices I've tested with are Gigabit capable but no luck
Had engineer come out on Monday and he said the same thing, he's got 6/7 users with himself having the exact same issue, advised that replacing the box didn't make a difference because he thinks it's a firmware issue (Yet to be confirmed of course but taking faulty hardware out the occasion only makes sense)
When he used his own equipment to test my connected (To see what speeds the Hub 4 is getting in and then outputting his speeds were matching mine and he said unless Virgin gets the modem manufacturer to push an update out he doesn't see how they'll resolve the issue)
He even said himself that the Hub 5 is pointless (Fitted 20+ of them to new customers and all 20+ couldn't get the Hub 5 to work) and said that the Hub 3 is currently the most stable but only provides speeds up to 600mb
A lot of users in the same boat currently from what I can see
Edward036
  • 34
Message 27 of 43
Sorry to hear that, it's such a headache and one we shouldn't have to be dealing with.
I wonder what the common denominator is as this doesn't happen to every customer, as you said the engineer had 6/7 customers with the same issue.
Where about's are you? Im in watford.
And still getting this service.
ihsaan96
  • 10
Message 28 of 43
Yeah not sure to be fair, the engineer thinks it's firmware related but if other users are on 1G with the SH4 then not sure...but yeah he's said he's got an email chain with his boss and they're trying to work out what it could be (Although from what I saw in the email he showed me they looked all a bit lost? Advising that changing the 5GHz WiFi channel will resolve this lol)
I'm in Birmingham, so it can't even be area related lol. Has to be something to do with the Hub not sending the 1GB signal through ethernet and WiFi
Edward036
  • 34
Message 29 of 43
Cheers, I wonder if changing the hub might work, a hub 6?
Edward036
  • 34
Message 30 of 43
Is this forum monitored by Virgin ? Just wondering if they have anything to say about my BQM.  Just had enough, its absolutely ridiculous that you have to even go onto a forum to try and fix your own broadband.
