carldisley
Hub 4 WiFi Problems
Recently had an unwanted upgrade to Hub 4 and all i have had is WiFi issues.
Working from home and struggling to get thrugh, even one day without issues.
I cannot get a human on the phone due to the pandemic and have left almost a dozen messages via web chat but nothing.
Can anyone recommend a step by step instructions of how to remedy this?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: Hub 4 WiFi Problems
What is your connection like using a direct connection with a Cat 5E or better ethernet cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
May I suggest that you download and install a Wi-Fi analyser to show if there are any foreign Wi-Fi broadcasts interfering with your own Wi-Fi signals and the locations that have poor signal strengths..
From there you can look at refining your own Wi-Fi broadcasts.
I use this one ...
WiFi Analyzer Premium - Apps on Google Play
wifi-2
