Daani350
  • 15
Hub 4 - Port Forwarding Not Working
Hi All,
I am only using the Hub 4 and not a secondary router, I have set up port forwarding and done this in numerical order but for some reason it doesn't work.
Does Port Forwarding actually work on the Hub 4? Any support would be appreciated.
  • 15.94K
  • 689
  • 1.56K
Re: Hub 4 - Port Forwarding Not Working
yes, no...maybe
Ports don't open unless you have a app on that port and allowed by the firewall and TCP you can scan for if open and UDP you can't.
