on 18-08-2023 11:10
I have been having this ongoing problem for around a month whereby, the internet connection on my Hub 4 drops every night between 22:00 - 00:00. All Wired and wireless connections are dropped with a slow flashing white light on the Hub. Sometimes power cycling the hub and the connection is restored within half an hour other times it doesn't come back online until the following day.
Any advice on troubleshooting this further is appreciated.
Andrew
on 18-08-2023 13:48
First thing is to set up a BQM to record these events as data for VM. Also check if there is ongoing work at your location.
Try in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
__________________________________
on 20-08-2023 10:55
HI @AWM81
Welcome back to our community forums and sorry to hear you have been having issues with disconnections for almost a month. We can understand the frustration caused and we want to best help. I have had a look at the system and there seems to be an issue with your hub power levels. For this reason, I have sent you a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
on 25-08-2023 12:20
Thank you for the info John, Please see link to the live graph attached https://www.thinkbroadband.com/broadband/monitoring/quality/share/1f1833f277ef5cdccb6a2dc6b14d5c0b27...
