  • 11
Message 1 of 19
Hub 4 Intermittent
So I received my Home Hub 4 on Monday and got it set up as soon as I got it. First couple of tests were grand 110mb/s etc, but every few hours the internet drops, both wired and wireless. This causes issues with the smart bulbs that I have as they turn on at full brightness when they lose Wifi as a safety measure. But because of this, they don't reconnect to the wifi and I can't get them off. Also happens during Movie streaming which is very annoying.
Hoping for a firmware update soon to fix this as I'm pretty unhappy with the service so far.
  • 1.59K
  • 85
  • 220
Superfast
Message 2 of 19
Re: Hub 4 Intermittent
sounds like a line issue rather than a firmware issue.
did you get a hub4 because you upgraded to the 1Gbps package, or a hub4 to replace a hub3 but remained on lower package?
post your line stats.
My Broadband Ping - spgray
  • 11
Message 3 of 19
I got it and remained on the lower package, I fell for the "you were selected" email they sent me. Never had this issue with the Hub3 and I had it for about 18 months.
I get this message when I "check service status" so thats helpful.
  • 1.59K
  • 85
  • 220
Superfast
Message 4 of 19
i would see if you can revert back to the hub3.
the hub4 is not necesarrily a better hub, and in some cases it doesn't handle lines with small issues as well as the hub3.
  • 11
Message 5 of 19
Define Line issues?
  • 1.59K
  • 85
  • 220
Superfast
Message 6 of 19
a line issue is anything issue that is between your hub and the cabinet/head end.
ie nothing within your control.
  • 11
Message 7 of 19
Um possible, I live in Northern Ireland so...I'm amazed I was even offered the Hub 4
  • 1.59K
  • 85
  • 220
Superfast
Message 8 of 19
why amazed?
the hub4 is being offered to customers in DOCSIS 3.1 areas where there may be conjestion issues, and moving them from DOCSIS 3.0 to 3.1 is helping to aleviate that, putting you on a hub4 has moved you from 3.0 to 3.1
however, the hub4 is less forgiving to lines with borderline issues. the hub3 is able to workaround those and you might never have seen a problem.
  • 24.31K
  • 1.39K
  • 3.09K
Message 9 of 19
@spgray wrote:
why amazed?
Because customers in Ireland are setup with virgin media IE not the same one used here.
https://www.virginmedia.ie/
However they have just enabled gigabit for their entire network in NI:
https://www.ispreview.co.uk/index.php/2020/11/virgin-media-bring-1gbps-to-3-million-people-in-london...
  • 11
Message 10 of 19
Usually new things "exclude NI"
I do know they are doing work around the area every so often so they must be trying to boost the service (I'm about 2 mile from Belfast City Centre). I'll maybe hold fire for a week or 2 and if it doesn't get any better I'll probably request the Hub3 back
